Colman
5 years agoFriendly Neighbour
Telus WiFi Hub
Hello, I am currently using Telus modem T3200M. My desktop computer is connected to this modem through an ethernet cable. All my other devices are connected to this modem through Wifi. I woul...
- 5 years ago
For the set-up you describe, there is no advantage to the Wi-Fi hub. The latter has benefits to Boost users, and saves Telus the need to install an ONT in some instances for homes without pre-installed Ethernet to the telecom cabinet.
5 years agoFor the set-up you describe, there is no advantage to the Wi-Fi hub. The latter has benefits to Boost users, and saves Telus the need to install an ONT in some instances for homes without pre-installed Ethernet to the telecom cabinet.
casperr0426
5 years agoNeighbour
