peliopoulos
4 years agoNeighbour
Telus Wifi Hub and Google Home Mini speaker
I just got internet set up in our new home and they gave me the white Telus Wifi Hub and one booster. The 5GHz and 2.4GHz signals are joined to one SSID. I tried to get the my Google Home Mini s...
- 4 years ago
I don't have that device. It does seem to be a fairly common issue. Here are a couple of links that discuss possible options:
How to Fix Common Google Home Connectivity Issues (puls.com)
Top 12 Ways to Fix Couldn't Communicate with Google Home Error (guidingtech.com)
Hopefully there is something of use for you.
rc
4 years agoRockstar
Try turning off the booster, and then see if you can set room.
If this does not work, then try turning off 5GHz on the wifi hub.
If you can get the device set up then undo your changes, on step at a time, to confirm what is causing the problem.
- peliopoulos4 years agoNeighbour
I'm pretty sure that I didn't properly reset the speaker before. I tried turning off the booster and that didn't do anything. However, I then figured I would reset the speaker again. This time, the speaker talked to me warning that I was going to reset it. I guess I was holding the button down wrong.
Thanks to rc and FuzzyLogic!
