DustinEdm
1 year agoNeighbour
Telus Wifi Hub - difficulty port forwarding with WAN
Hello, I recently moved into a new building that has a new Telus Wifi Hub for my unit. I am attempting to run a local server for board games with friends on the app FoundryVTT. This application usual...
1 year agoHero
Do not set a static WAN IP address unless you have have been assigned a static IP address by TELUS.
If your WAN IP assigned by DHCP is not the same as what you see at https://www.whatismyip.com/ then you are behind carrier grade NAT and port forwarding will not work no matter what you do. Nighthawk mentions this in his post above but you have not indicated if this is the case or not.
