DustinEdm
1 year agoNeighbour
Telus Wifi Hub - difficulty port forwarding with WAN
Hello, I recently moved into a new building that has a new Telus Wifi Hub for my unit. I am attempting to run a local server for board games with friends on the app FoundryVTT. This application usual...
DustinEdm
1 year agoNeighbour
Ah good point, I didn't think about the DMZ rendering all the port forwarding settings moot. The whatsmyIP website does provide the same address that the server believes I have.
I've removed the DMZ, and went back to the standard port forwarding application. I've rebooted the modem after all of these were applied and refreshed the application. But it still looks like the connection is closed.
Current setup is (with screenshots):
- Port forwarding enabled on my public IP on port 30 000 to point at my server
- Special application of port 30 000 to prevent the NAT from interfering
- All other undefined ports enabled (I still feel this is poor practice, and may switch the server's port to be something like 8001 or a different usable port that is covered under a different firewall tab, but right now I just need to understand the mechanism for allowing access for my friends)
If my research is correct, my IP address is being changed frequently due to WAN, and I should request a static IP. However I'm poorly versed in how to request a static IP in the following fields and how I should request the modem to set this up
1 year agoWhile I can't see the screenshots yet (pics are moderated) I can confirm that you should not need a WAN static IP. My WAN IP hasn't changed in a very long time. I'd guess at least 6 months or more. Static IPs are usually only available on business connections if I remember correctly. Setting your PC on a static IP within the LAN is probably a good idea.
- DustinEdm1 year agoNeighbour
Did a bit more testing and yeah, the whatsmyip address matches the Foundry address invitation link it generates on the app. Double checked the port forwarding rules and it looks like its setup correctly with the guides in Telus forums and the Foundry support pages (https://foundryvtt.com/article/port-forwarding/). Will attempt to do a full factory reset of the modem and try again.
