eyestalk
6 years agoFriendly Neighbour
Telus Wi-Fi Hub re-enabling wifi despite being in full bridge mode?! DHCP chaos.
Hello All, First post here... have had Telus 750/750 for a week now. This morning (at about 3 am), it seems my Telus Wi-Fi Hub (white diaper genie style), re-enabled the WiFi services on it, de...
- 6 years agoSFP and SFP+ are not compatible hence why I mentioned the need for a media convertor.
You could also use a Ubiquiti Edge Router ER-X-SFP but it's got some issues with the Nokia SFP Telus uses and is not unifi.
With the media converter your simply converting the fiber SFP which is max 1Gbps to single 1Gbps Ethernet port you can just plug into your current hardware.
eyestalk
If I can just plug direct into SFP from the fibre coming into the house that would make things even easier.
What do you think of going with something like Ubiquiti's UniFi Dream Machine Pro? Has a 10G SFP+ port for WAN, which should be backwards compatible?
It's still in early access, but hopefully should be generally available soon.
Features:
- 8-Port gigabit switch with 10G SFP+ port
- Dual WAN ports for redundancy and load balancing: 10G SFP+ and 1G RJ-45
I was probably going to go UDM Pro anyhow to simplify my install, instead of running Cloud Key Gen 2+ and a USG security gateway.
kevhawk
6 years agoOrganizer
- doctorkb6 years agoNeighbour
kevhawk : "SFP and SFP+ are not compatible hence why I mentioned the need for a media convertor."
Not entirely true. There is backwards compatibility, at least with the Ubiquiti equipment. You can put an SFP cable/ONT into an SFP+ port -- you may need to force it to 1Gbps, but other than that, there's no issues.
kevhawk : "You could also use a Ubiquiti Edge Router ER-X-SFP but it's got some issues with the Nokia SFP Telus uses and is not unifi."
The Ubiquiti Security Gateway Pro (USG-4P) has SFP ports and works perfectly with the Nokia SFP provided by Telus. I have three units all set up and working correctly with this.
- eyestalk6 years agoFriendly Neighbour
Thanks. Will look into a media converter to eliminate the Telus Hub
Related Content
Home services cancellation fee applied despite special circumstances agreement
Last summer I contacted telus to renew our father in law's internet and home service agreement. I was offered a good plan but I explained, I'm the POA for a 91 year old senior with dementia. He likel...Solved282Views2Comments
