Ben3
4 years agoFriendly Neighbour
TELUS Wi-Fi Hub - Port forwarding
In short, I have a local web server that I use for testing. It is not used publically. I am trying to run this on port 44301 (SSL) so basically, I want https://www.MYDOMAIN.com:44301 to go to ...
- 4 years ago
I don't believe port 443 is blocked. I'm using it without issue:
TELUS HSIA Security Measures Policy | TELUS Support
Ben3
Sorry. It posted before I finished.
Network > Firewall > Port Forwarding
- I have tried several different combinations.
- I tried:
- Public (44301) -> Private (443) This works fine with IIS (verified with a local hosts file)
- Public (44301) -> Private (44301) This works fine with IIS (verified with a local hosts file)
- Public (443) -> Private (443) (I know this should not work because it is blocked)
All and all, it all seems to set up correctly, it is just the port forwarding that does not seem to be working.
FuzzyLogic
4 years agoI don't believe port 443 is blocked. I'm using it without issue:
- Ben34 years agoFriendly Neighbour
That is interesting. It seems that it is blocked for me. Are you using Pure Fiber? Do you have a business account? They don't block the port for business accounts.
Please confirm.
- FuzzyLogic4 years ago
I'm on Internet 75 home account.
