niklaus
5 years agoNeighbour
Telus T3200M modem and Telus wifi hub.. but the hub is not working
I have a Telus modem T3200M and a Telus wifi hub. The SETUP: Inside the panel where the Nokia ONT is, there is an ethernet cable coming from the ONT going to the WAN port of the modem. From the ...
5 years agoHero
If you want to use the Hub as your router just swap it with the T3200.
If you need WiFi access point to be somewhere else other than next to the ONT then just comnect from the ONT to the port to the house and put the Hub at the other end in the house.
Make sure you are using the WAN port on the Hub to connect to the ONT.
