leonki
1 year agoNeighbour
Telus Pure Fiber NH20A in Bridge mode - PPPoE?
I'm in Toronto and recently upgraded from Bell to Telus and am super happy with the service. I wanted to confirm that the setup I have is the recommended / optimal solution. I use a Ubiquity Dream Ma...
- 1 year ago
We’re glad to hear you’re enjoying the service! Regarding your setup: what you’re seeing is actually expected behaviour with the NH20A. Even when in bridge mode, the NH20A requires its WAN interface to remain active to maintain the physical link with the fibre ONT and allow passthrough for your own router (in this case, your Ubiquiti Dream Machine) to authenticate via PPPoE.
If you want to avoid the NH20A from acquiring its own public IP, you could try removing its PPPoE credentials and keeping the WAN interface active, but behaviour may vary — your current setup ensures reliable connectivity and is supported.
darreno
1 year agoNeighbour
Here are my 2 cents, I have all Unifi equipment as well and I don't even use the TELUS modem, the fiber comes into a white box that has 4 ports on it, this is what I was told is the wan device, I plug my Gateway into that and then my switches and APs into the switch. The TELUS modem with Wi-Fi and Lan settings is bypassed. I received an internet address into my Gateway, and it worked great, port forwarding, security rules, and VPN all worked great. Hope this makes sense.
