aamar_maqsood
4 years agoNeighbour
Telus installed fiber optic beyond easement without permission
Telus came to our property and asked that they will be installing fiber optic on our property. I asked them that I don't want the easement to be extended and that if they will be installing within t...
- 4 years ago
aamar_maqsood wrote:Also, the owner of the house did not sign the papers for installation.
Are you not the owner of the property? If you aren't then there is nothing you can do.
giantbrownguy
4 years agoRockstar
Honestly, I would talk to your city hall, and maybe a lawyer. Unless you've had a survey, there may be a misunderstanding of the property line, but they should hopefully be forced to remedy it.
- polecat4 years agoAll-Star
I assume you know where the property pins are. I worked in power underground and if this is in an older subdivisions things are not always what a person sees. Locate the pins city hall can do that and go from there. Sometimes right of way has changed over the years for extra utility clearance. People move and all memory is lost in time.
