andreww
4 years agoNeighbour
Telus "can't give you fibre as the signal is too low"??
I am in Aspen Woods, Calgary. It is a house about 5 years old. The "fibre drop" (as in outside fibre cable) people tell me that fibre had been installed outside when it was built, as was the cas...
- 4 years ago
Hi Andrew, it can certainly be the case if the switch/hub is too far away. Sometimes other infrastructural limitations, such as limited number of ports, available bandwidth, etc can also impact availability.
Dimo-X
Moderator
4 years agoHi Andrew, it can certainly be the case if the switch/hub is too far away. Sometimes other infrastructural limitations, such as limited number of ports, available bandwidth, etc can also impact availability.
Related Content
Can't log into T3200M router - "192.168.1.254 uses an invalid security certificate" self-signed
This is a new one - when I try to log into my T3200M router I get security warnings like "192.168.1.254 uses an invalid security certificate" because it's "self-signed." (that's on FF) and with Chrome...Solved5.2KViews2Comments
