Arvan
4 years agoNeighbour
Telus boost wifi not working with ethernet switch
I recently picked up a Tp link ethernet switch (TL-SG1008D) to use with my telus wifi booster and a few other devices. I have run into a problem though, when I connect JUST the wifi booster to the sw...
Arvan
the ethernet switch is connected to the t3200m modem, and the boost is connected to the ethernet switch
4 years agoThat in theory should work fine. The TL-SG1008D is a standard unmanaged gigabit switch so I can't think of any reason why it wouldn't work, unless there's a hardware issue. If you don't connect the Boost, but connect at least two other devices by ethernet to that switch, are there any connection issues with the connected devices?
- gurpreet22034 years agoNeighbourI have the same exact issue. In my case the boost works for a few days and then the whole switch stops working (no internet to the connected devices)
The boost connected directly to the Telus hub works flawless.
Any ideas? I have to connect 4 boosts to my Telus hub and there are only 2 vacant ports.
