Arvan
4 years agoNeighbour
Telus boost wifi not working with ethernet switch
I recently picked up a Tp link ethernet switch (TL-SG1008D) to use with my telus wifi booster and a few other devices. I have run into a problem though, when I connect JUST the wifi booster to the switch it works fine. But If I connect something else such as my ps3 or optik tv box the booster stops working and my phone wont even connect to it the booster.
- Nighthawk
Is the switch connected to the main Telus router or is the switch only connected to the Boost?
- ArvanNeighbour
the ethernet switch is connected to the t3200m modem, and the boost is connected to the ethernet switch
- Nighthawk
That in theory should work fine. The TL-SG1008D is a standard unmanaged gigabit switch so I can't think of any reason why it wouldn't work, unless there's a hardware issue. If you don't connect the Boost, but connect at least two other devices by ethernet to that switch, are there any connection issues with the connected devices?
