ShylaJean's avatar
ShylaJean
6 months ago
Telus Android Tv Box Power Supply Not Working
Wondering if anyone has links for compatible adapters for the Telus TV Android box? This is the third time the adapter stopped working on me and with the postal strike I’m not sure when I’ll get my replacement. I bought one off Amazon but it is not compatible. Any help would be appreciated!
  • Looks like the one you got, the end is
    2.1mm X 5.5mm
    The one I got is 5.5x2.5mm
    The other one I linked has that size adapter
    • ShylaJean's avatar
      ShylaJean
      Yes thank you! I searched my city and found a universal adapter with multiple sizes and one of them worked! Finally have my tv again! Thanks so much :)
  • This is the one I got in January and still working. Not listed anymore though other Arkare are. Looks like it was changed to white and has multiple adapters. The one I got just had the right size without adapters. What did you get and what is not compatible?
    Arkare 12V Power Supply 2A AC/DC...
      ShylaJean
      This is the one I bought. I checked the size, volts, etc., and it seemed to be the right choice, but it won’t fit the Android Tv box. The end is the right size, but the silver casing is too wide for the tv box port.
      https://a.co/d/gbWBggr
  • just get one from amazon. Can't link the one I got as it is no longer listed.
      ShylaJean
      I did buy one off Amazon and it is not compatible with the Android TV box. Was hoping someone had a link to one that actually fits before I keep buying and returning them.
