Ray77
2 years agoNeighbour
Speed Test from T3200m shows 350/250, suppsed to be 940/940
How can I have Gigabit speed back? I've made 3 times' calls to tech support. Just hour ago, I made another call and the agent kept saying 400(D)/300(U) seems right since the speed test took pla...
- 2 years ago
Speeds over wireless are never guaranteed. Too many variables that can affect it.
Ignore the speedtest in the admin section of the T3200. It's broken. I get 362/273 from the T3200 speed test but 944/948 from speedtest.net when on a hardwired computer. What do you get if you run a speed test from a hardwired computer?
2 years agoSpeeds over wireless are never guaranteed. Too many variables that can affect it.
Ray77
Thanks Nighthawk for your answer.
You're right. The result from T3200m and SpeedTest.net (wired) shows totally different output.
Mine is 928/849 which is very good for my usage.
I owe big apologies to 3rd Telus technician who tried to help me several hours ago.
And thanks Nighthawk and big thanks to 2 previous Telus technicians who spent hours trying to fix it.
