ron9
2 years agoNeighbour
Sony Bravia TV remote - TELUS controls don't work??
I just got a nice 2023 Sony Bravia XR-55A80L, and duly followed its instructions to setup my Telus box (technicolor IPV5050), that also worked fine with my previous Sony Bravia. My new Sony remote w...
miglenda
1 year agoNeighbour
Hello...I too have a Sony Bravia smart 55" Tv - Model X85K, and no matter how I try, I can't program my telus Optic control to work...W have an older (10yrs) Bravia in another room and it works find....Help, Please.
Thanks
Best
Michael
A-B
Community Manager
1 year agoYou can try the following steps, and if it doesn't work you can reach out to our Tech Support team directly for further assistance.
1. Press and hold both the input and OK buttons on your remote for 3 seconds. The green LED should stay on.
2. Enter the code 022 using the number pad. The green LED will blink twice and then go off.
3. Test the mute or volume up/down button. If these work, you're done.
