Kyl
2 years agoOrganizer
Some traffic seems slower than others
I noticed during my trial of purefiber that some services I use appear to be slower than when I use those same services on another internet connection. Does telus throttle or change the speed of some...
- 2 years agoThanks for your reply, I am not sure what was slowing things down, I may have jumped the gun reporting a speed problem. It seems to have cleared up after 24h.
I think it was the specific servers I had connected to while testing the VPN and other protocol speeds.
MrSL
2 years agoRockstar
Hi Kyl , do you have fiber optic running directly to your property?
I switched 5 months ago to the 1gb plan because I do and the network speeds never really vary:
A good widely used speed-test is "Ookla" which can be installed on both network and mobile for testing.
Kyl
