feiya200
3 years agoNeighbour
SFP Switch in front of Telus Network Access Hub
Currently I have Telus 2.5G internet. The green fibre along with the nokia SFP module is attached to the Network access hub (acting as a router too). However I also bought the 5 static IP package...
- 3 years ago
feiya200 Wrote: Currently I have Telus 2.5G internet.
This is the key point. I believe you are going to have to leave your Telus device inline prior to obtaining your additional IP addresses. So Telus device in bridged mode, then from the 10Gbps port on the Telus device, out to a 10Gbps switch. That will allow for the multiple IP addresses.
I would recommend that you then link to some sort of routing device capable of the 2.5gbps speeds as you will want to protect your various devices from attaches as well a routing and firewall.
I have a similar setup, however I only utilize 2 IP's. I have the Telus NH20A in bridge mode, feeding to a MikroTik CRS305-1G-4S+IN switch, then on to 2 Unifi routers capable of ingesting 10Gbps speeds. The out to additional switches and AP's
DrPacman
3 years agoRockstar
feiya200
Sorry I have to ask you one more follow up question, how do you connect NH20A with MikroTik CRS305-1G-4S+IN?
I have NH20A as well but the 10G port on it is a RJ45, and MIkroTik all 4 ports are SFP+, right?
- DrPacman3 years agoRockstar
feiya200 Wrote: How do you connect NH20A with MikroTik CRS305-1G-4S+IN?
One thing to note: The MikroTik can act as both a switch or router, it must be set as just a switch for this to all work..
Personally I have a number of 10GBase-T SFP+ Transceiver RJ-45 transceivers to adapt between the RJ45 and SFP+ fibre.
Some of the brands include ONTi (ONT-C1TE-R01), (Wiitek SFP-10G-T) seem to work for me, your milage may vary... Cheers
