Hoser25
7 months agoNeighbour
Setup Boost Wifi 6 Lite as an access point to extend existing LAN?
Hey all, got fibre installed 10 days ago and finally getting to cleaning up what the tech left me with. He was great, but custom lan setups aren't his job. Currently my NAH connects to my router (As...
- 6 months ago
Hey Hoser25 - Our Boost Lites work together as APs so I don't believe that you'll be able to extend your Asus router's network. You might be able to set them up and login to their UI to change the SSID and Password and that may work but one must be connected via ethernet to your Asus router.
You might run into interference issues though
El-Eric
Community Manager
6 months agoHey Hoser25 - Our Boost Lites work together as APs so I don't believe that you'll be able to extend your Asus router's network. You might be able to set them up and login to their UI to change the SSID and Password and that may work but one must be connected via ethernet to your Asus router.
Related Content
- 29KViews35Comments
