PeterPopOff
3 years agoFriendly Neighbour
Running internet through cable
I have a fifth wheel I want to get internet in but its only prewired for cable tv, I've heard somewhere that it is possible to run the same signal through it but I'm struggling to find an answer and ...
- 3 years ago
PeterPopOff wrote:
The first one is not an issue as I am confident Telus will provide service where I am, the power lines for the house on this property go into a pump house and then go underground to the house and trailer lot and the house already has Telus pure fibre subscription for the trailer lot there's a satellite on the pump house with a coax cable that goes underground to the trailer lot and I figured that best case scenario would make it as easy as just unconnecting the cable from the satellite and using some adaptersThat's key information that was not clear in your initial post. Sounds like all you need is to connect the coax to the MoCA port on the router and then get some MoCA adapters to use in the trailer. You will need to run your own coax from the router to the trailer.
3 years agoHero
There are 2 separate issues here.
- Will TELUS provide service to a location that does not have a fixed building/structure/address
- Assuming above is a go then you can run a network connection from the router (installed somewhere?) via coax to MoCA adapters inside your fifth wheel to get an Ethernet connection.
- PeterPopOff3 years agoFriendly NeighbourThe first one is not an issue as I am confident Telus will provide service where I am, the power lines for the house on this property go into a pump house and then go underground to the house and trailer lot and the house already has Telus pure fibre subscription for the trailer lot there's a satellite on the pump house with a coax cable that goes underground to the trailer lot and I figured that best case scenario would make it as easy as just unconnecting the cable from the satellite and using some adapters
- xray3 years agoHero
