KeepDiscovering
1 year agoNeighbour
Replacement Remote TV Digital Box
Hello! Anybody have any luck getting replacement Bluetooth remotes for the Telus TV Digital Box? I called Telus and they told me they can't send out replacements and I would have to go to my nearest ...
- 1 year ago
Unfortunately, it looks like you got some incorrect information. You should absolutely be able to order a replacement remote from an agent and compatible remotes are NOT available in stores (the Slimline II is a legacy remote that works with legacy equipment and does not have Bluetooth capabilities). Maybe send a DM to the TELUS Support username??
For now, I'd recommend trying to factory reset your remote to see if you can bring it back to life (instructions). Failing that, you can use the Google Home mobile app as a remote until you can get a replacement.
davidvh
1 year agoNeighbour
I, too, am looking for a replacement Telus bluetooth remote.
Like the user KeepDiscovering, I also am having difficulty finding an agent who can send me a replacement.
KeepDiscovering
1 year agoNeighbour
I was contacted by a support member who ended up sending me an entirely new box as it would come with a new remote, I'm assuming you will have to go the same route
