brianj411's avatar
brianj411
5 years ago
Solved
Question regarding ethernet connection in an apartment
Hello,  I live in an apartment with the modem and router set up in a closet on the first floor. I've been getting unstable wifi for the past couple months for whatever reason and wanted to move on t...
  • RonAKA's avatar
    RonAKA
    5 years ago
    The ethernet ports on the T3200M are the yellow ones. So, you would need an ethernet cable from those ports to your room.
