brianj411
5 years agoNeighbour
Question regarding ethernet connection in an apartment
Hello, I live in an apartment with the modem and router set up in a closet on the first floor. I've been getting unstable wifi for the past couple months for whatever reason and wanted to move on t...
- 5 years ago
The ethernet ports on the T3200M are the yellow ones. So, you would need an ethernet cable from those ports to your room.
polecat
5 years agoAll-Star
brianj411 RonAKA Looking at top cables 4 coming from modem to where the green wire are correct? Unplug 1 or 2 or 3 or 8 and plug into your laptop do you get connection Yes or no? If you do modem working ok. I assume these green go to bedroom? I think they are wired to carry telephone not wired for internet. Are the wires cate 5 or 6 if they are the color codes probably don't match the proper positions at both ends of their runs. If your laptop works on 1-2-3-8 i think wiring is messed up one end or other or some wires not connected. You probably a computer guy to sort it out. Polecat
