dshuffman45
4 years agoNeighbour
Question about Unlimited Data Plan Overage Charges after Plan Change
I recently changed to unlimited internet data. But My Telus, is not showing the change and says I have gone over my old usage limit. Does anyone know if will get charged for the usage after I changed...
- 4 years ago
Your data may be prorated. Let's say your plan had 100GB of data, and you consumed 70 GB in the first 15 days of your billing period. If you change to unlimited on Day 16, the unlimited package starts then, so you are billed for the excess 20 GB you use on the old plan.
4 years agoYour data may be prorated. Let's say your plan had 100GB of data, and you consumed 70 GB in the first 15 days of your billing period. If you change to unlimited on Day 16, the unlimited package starts then, so you are billed for the excess 20 GB you use on the old plan.
- dshuffman454 years agoNeighbour
What do I do if I keep getting charged if I am still on my old limited plan?
That has happened to me before, had to keep calling telus for a refund. And on my Telus page, it is still showing me old limited plan internet plan even though I changed to unlimited data.
- NFtoBC4 years ago
Then you will need to call in to get them to update, since your change appears not to have been applied.
