wudao2001
4 years agoNeighbour
- 4 years ago
- Logout
- THANKS ANNA!!!
KRC
3 years agoFriendly Neighbour
Hi, was your issue resolved. I also got a new telus router and hub which is not getting connected with Redlink.
Pruthvi077
3 years agoNeighbour
Hi, just use TP Link network switch, attach with your router or anywhere the Ethernet cable available, and then Redlink attached to TP Link the it should work.
Mine is working that way.
