wudao2001
4 years agoNeighbour
- 4 years ago
- Logout
- THANKS ANNA!!!
KRC
3 years agoFriendly Neighbour
Hi, was your issue resolved. I also got a new telus router and hub which is not getting connected with Redlink.
Moo
3 years agoNeighbour
The V6 is your wireless access pt, cannot bridge any of it's ethernet ports. Pull the cover off the network access hub, use a flat screw driver at the top in the middle should pop off. Sometimes they put the tiny screw in the bottom for extra holding power. The sticker will be there, at bottom of sticker will say admin and a password. So when you type in 192.168.1.254 type admin and password. That will bring up the interface and you are talking to the nah now. Click the green coloured band saying broadband then click tab saying local port mode, click port 1 bridge, apply changes, restart modem, port 1 on nah should now be in bridge mode and will show under the broadband banner as enabled. Plug in the honeywell to port 1 should blink green now. The honeywell device is a gateway too.
