wudao2001
4 years agoNeighbour
- 4 years ago
- Logout
- THANKS ANNA!!!
paulpooco
3 years agoOrganizer
My T3200M hasn't hasn't had an update in 2 years, that sounds wrong.
I work for TELUS just not the department that goes to peoples houses.
