wudao2001
4 years agoNeighbour
- 4 years ago
- Logout
- THANKS ANNA!!!
paulpooco
3 years agoOrganizer
Unrelated to connection issue, The Total Home Connect Thermostat app sometimes will not show the system doing anything but either the fan is on doing circulate or the heat is on. I guess the Thermostat could turn off heat or circulate and it just take a bit for Heatpump system to finish what it is doing?
