wudao2001
4 years agoNeighbour
- 4 years ago
- Logout
- THANKS ANNA!!!
soloyo
i have the same issue, just got installed few days ago. WIFi6 is not a router just a booster. the issue is with the white hub that's the router. worked with not issues with Shaw
