wudao2001
4 years agoNeighbour
- 4 years ago
- Logout
- THANKS ANNA!!!
Dnice40
How do we fix it?
wudao2001
Swapped the white tower modem with a black modem and problem solved. This also solved connection issues with other older products which can only connect to 2G networks.
- KRC3 years agoFriendly NeighbourHi, can you please let me know the model # of the booster?
- rcruz3 years agoFriendly NeighbourDid you have to pay extra or go through extensive process to swap out your booster to a black router/modem? Looking to have mine swapped out too.
- Dnice403 years agoNeighbourDidn't have to swap. Just used the same white tower and went into the settings to "enable bridge".
- rcruz3 years agoFriendly NeighbourI have the wifi 6 booster but it does not give me access to the IP gateway 192.168.1.254 but rather lets me in on the 192.168.1.41 which does not have the LAN menu to enable bridge. I tried using the "admin" username and password on the back of my wifi 6 booster but it just won't allow me to log in.
