wudao2001
4 years agoNeighbour
- 4 years ago
- Logout
- THANKS ANNA!!!
Dnice40
How do we fix it?
- wudao20014 years agoNeighbourSwapped the white tower modem with a black modem and problem solved. This also solved connection issues with other older products which can only connect to 2G networks.
- KRC3 years agoFriendly NeighbourHi, can you please let me know the model # of the booster?
- rcruz3 years agoFriendly NeighbourDid you have to pay extra or go through extensive process to swap out your booster to a black router/modem? Looking to have mine swapped out too.
- Dnice403 years agoNeighbourDidn't have to swap. Just used the same white tower and went into the settings to "enable bridge".
