wudao2001
4 years agoNeighbour
- 4 years ago
- Logout
- THANKS ANNA!!!
wudao2001
It just won't connect. It connected ok for a few minutes and then refuse to connect again. Tech guy who set up the thermostat says he encountered many instances when the isp is Telus and the modem is the white one as opposed to the black one.
Deuce
I have the exact same issue...Telus tells me the problem is with Honeywell, the supplier of the device and Honeywell says its related to Telus. Anyone?
- Cheapshot_ND4 years agoNeighbour
I have the same issue. Both of what Telus and Honeywell is correct. I'm sure it's more on the Telus side. I think their router is picking up the communication to Honeywell as a hacking attempt. The solid yellow light means it's on the network but, it's unable to get to the Honeywell server.
- loyalClient4 years agoCoach
Do you know what the firmware version of the WI-Fi 6 units are? and is there any switch in your environment?
