SaitamaReborn
6 years agoOrganizer
Port Forwarding on Telus WiFi Hub
Howdy, I just got a response from Telus Tech support regarding Port Forwarding: From chats with network team and colleagues there is nothing from Telus’s end blocking the ports you are lookin...
6 years agoWhat port numbers are you trying to forward? There are some that are blocked on residential accounts from accepting incoming traffic.
- SaitamaReborn6 years agoOrganizer
My existing config was to open ports so that I can
-reach my NASs ... which are any ports really.
-Apple Remote Desktop/VNC: 3283 and 5900
-some services provided by my NASs ... which are also completely anything at all possible
Ive tried setting the firewall settings to 'low' and using these known ports to try to port forward to my services... didnt work.
Ive tried turning off the Telus Wifi Hub Firewall, disabling the intrusion detection... nope, still unreachable.
If I port scan my IP, I get:
Open TCP Port: 53 domain
Open TCP Port: 7547 cwmpOpen TCP Port: 10053
Open TCP Port: 55661
Open TCP Port: 58849
