Bearsfan
2 months agoOrganizer
Not able to use Alexa with Telus Home Assistant
The other day I went to turn on one of my Telus digital boxes via Alexa and it responded by saying sorry XXXXTV is not responding. I tried the other two cable boxes via Alexa and they too would not r...
- 1 day ago
An update: We identified the issue late last week and worked with our vendor to resolve the Skills issue. Our testing showed it was working fine as of Friday. Can you confirm that it is? If not, please disable it then re-enable it and try again.
Thank you so much for your patience with us!tgrosse tgrosse ecoulter Marie17 ketev48046
Edit: Marked as Solution for visbility
This reply was moved from another post
Kerbis
2 months agoNeighbour
Does anyone know of a fix, work around or ETA to when this issue will be resolved? My TELUS system stopped working with my Alexa on Friday, June 13 and I have not been able to re-link the accounts since my Alexa works with every other SmartHome device that I have but will not control or relink with the Telus home assistant Help.
