ewantaylo
4 years agoNeighbour
No connection to anything other than google sites over LAN, but a full connection over wifi- except!
This is for a telus wifi hub router/ modem combo. My wifi works, but my LAN doesn't. Wifi will load anything I want, but a wired connection will only load google services. I've tried with two laptop...
- 4 years ago
Have you played with any setting in the router? If so what? This was from yesterday, has it resolved itself?
What's the model # of the wifi hub router/ modem combo? what is the physical signal path/chain of your present equipment?
Reboot
Factory reset
Physical wiring changes
LAN DHCP static addressing, range setting
MAC address filtering allow/denial list
IP conflicts
etc
sonofdust
3 years agoFriendly Neighbour
Oh MY!! Someone else has the same trouble I'm having. Within the past 2 days this has started happening. I can access only google.com searches and youtube . All other websites are "unreachable". I use Windows 10. Driving myself crazy trying to solve this. I thought it had to do with a recent windows update which I have "rolled back" but still have the same issue. Is there a solution to this?! Please help.
The only way I can get full internet access ( DNS seems to work) is that I restart my computer. I then get internet for a period of time, but when I walk away from my pc and return some time later, no internet works except access to google sites/products. I've reset my DNS to alternative DNS settings but nothing works.
Is there some Telus tech support that can work this out? It's something that started 2 days ago.
