Juicebox
5 months agoNeighbour
Modem/Router settings Causing issues with VOIP
So i have the following products
NH20A - modem
The white cylinder for the WIFI booster.
I have been trying to find a setting where I can disable my "SIP ALG" (Application Layer Gateway). Typically, by default this is enabled. Which is causing issues with VOIP calls that I place on hold.
The router/modem UI has changed now that I have Fiber internet. On my old Router/modem the UI had more in depth setting that were accessible. including enabling or disabling SIP ALG
I have spent hours on the phone trying to explain this to the agents, They keep telling me that this setting is automatic and cannot be enabled or disabled, which I know is not true.
Has anyone else had a similar issue? i am wondering how I can get TELUS to disable this feature
- BoardsonNeighbour
I experienced call drops until I logged into the router settings and disabled SIP ALG. My voip provider said it interferes with call handling, and after turning it off, things got way better. Also, setting QoS rules to give priority to my ATA device really helped with call quality. Some routers bury these settings, so it took a bit of digging, but it was worth it.
- BoardsonNeighbour
I had the same kind of issue and fixed it by switching SIP ALG off in the router settings. Also set static ports if your router lets you — it helped voice quality.
- SmarioOrganizer
Usually this setting ,it is in a telus business account.
or
This setting is also found in business routers or VOIP POE managed switches would also have the SIP ALG Setting.
Power Over Ethernet Managed switch- cisco, tplink, other brands....
- SmarioOrganizer
A business router or POE Managed switch contains SIP ALG feature
- TELUS_Support
Hi Juicebox - this will be something that maybe our seasoned members have experience with
+Nighthawk FuzzyLogic xray - Are any of you familiar with this?
