Dan85's avatar
Dan85
5 years ago
Solved
MOCA device help please.
Currently I am using the Arcadyan modem/router on bridged mode.   The connection source is through Fibre.  The Arcadyan modem has MOCA Capabilities which I am utilizing with another Actiontec MOCA ...
  • brians's avatar
    5 years ago
    Yes you can use two or more moca adapters instead. I do this and get near full gigabit speed from them.  Just plug Ethernet from one to your router lan and other one to computer or switch elsewhere connected via coax. Can even send vlan across These and I do to send t3200m lan for Optik and my pfsense to upstairs bedroom via managed switches - eg port 1 on switch is pfsense lan and port 2 is optik lan.
    taking off moca filter may allow neighbors access to your network if they have an adapter. By default they are programmed with no security.
