LR1
4 years agoNeighbour
LAN connection when bridging
Hello I have a T3200M gateway from Telus. I want to add a different router. I understand that I can bridge my T3200M and then connect my new router to LAN 1. I assume by doing this the WI Fi signal fr...
WestCoasterBC
4 years agoCPU Alum
The wireless radios are still turned on when you use your own router in port 1. You have to manually turn them off logging into the T3200. Ports 2,3,4 are still active on the T3200. If you have Optik TV, always let the T3200 handle that.
You don't need to put the T3200 into bridge mode you can just use your own router in port 1
