jlieu
2 years agoFriendly Neighbour
Issues with IP addresses not being assigned
I am having issues with IP addresses not being assigned when I have a switch plugged in at a specific outlet. The issue doesn't occur right away, the network will be fine for a day or two, sometimes ...
A-B
Community Manager
2 years agoNFtoBC
2 years agoMy guess is damage to the Ethernet cable between the 16 port switch and the problem outlet.
I’d suggest some further troubleshooting:
- try different port on 16 port switch
- test the connected devices elsewhere
- consider running a temporary ethernet patch cable between the two points to see if the existing cable is the problem.
- jlieu1 year agoFriendly Neighbour
I've tried troubleshooting the outlet however it doesn't look like it is the outlet or cables. The network is fine if I remove the switch at the outlet and just have the Telus wireless AP plugged into the outlet. The problem only occurs when I have the switch plugged into the outlet and the Telus AP plugged into the switch. Perhaps the Telus modem stops assigning IP addresses after a certain amount of devices are connected to the network?
- marv19987001 year agoFriendly NeighbourUpdate: My wife said she was controlling the internet access thru the telus app on her phone and that was the root cause.
