KJaswal
26 days agoOrganizer
Issue with 5G SSID saying password incorrect on iPhone 15 pro/plus after typing it correct
I turned my smartsteering off for my modem since it was causing issues with the wifi turning on and off on both my pc laptop and my 15 pro and 15 plus iPhones. Splitting the bands helped out with the wifi a lot but my 15 pro and 15 plus were connecting to the 5G band for a few days after splitting the bands but since yesterday are not connecting to the 5G and keeps saying incorrect password even though I keep inserting the correct password. Also my ASUS Pc laptop was not connecting to the 5G either saying connected but no internet. Both devices work fine when connected to 2.4 though as well as my laptop is showing connected and secured for the 2.4G. Currently the 2.4G is only connected to my downstairs tv (my modem is placed upstairs). The 5G is connected to my upstairs tv and is working fine on it also my father has the latest 17 pro max and is on 5G and has never had any problems that i have had on my phone. Also the 5G is connected to my Apple laptop and I also have and old iPhone 5C that also has no problems with connecting to 5G. So this issue is only happening with the two iphone 15 series models and my PC laptop. 24 hours later from last night to tonight it still says incorrect password on my 15 series phones when trying to connect to the 5G. Is there a way to fix? the 2.4 one is the network ive been connecting these 3 devices to for the time being.
- xrayHero
When you turned off Smart Steering it creates 2 separate SSIDs. Did you verify you are trying to connect to your 5G SSID and not some other one (neighbours)? Go back to the router and verify the SSID it is using for 5G.
- KJaswalOrganizer
Yes my wifi is telus2103 and it has the two seperate id's of 2.4 and 5G, the 5G was connecting to my phones but now keeps saying incorrect password when trying to connect to 2103-5G. ive tried to reset network settings on the phone I saw suggested online but still says incorrect password after putting in the correct one
- FuzzyLogic
With smart steering disabled you can set different password per band. Maybe change the password for the 5Ghz band on the router and then try connecting your phone with the new password.
- FuzzyLogic
Maybe try disabling Smart Steering and setting up seperate SSIDs for the 2.4Ghz and 5Ghz bands. Then test if your devices are able to connect to one or the other bands.
Also you may wish to check if you have possibly paused devices in the Telus Connect app.
