Variable
2 months agoFriendly Neighbour
Is T3200M compatible with Wifi Boost 7 (v3.0)?
I currently use the Actiontec T3200M connected directly to the fibre receptacle on the wall (I live in an apartment that is pre-wired for fibre). I recently upgraded to PureFibre Gigabit. The CSR sta...
- 2 months ago
Hey Variable - the Boost 7 needs to be plugged into the Network Access Hub so your problems may be due to the Boost 7 being connected to the T3200
2 months agoHave you tried disabling the WiFi on the T3200? You might need to connect the Boost 7 to an NAH.
- Variable2 months agoFriendly Neighbour
Yes, I've disabled Wifi on the T3200 and confirmed that I'm connected to the SSID corresponding to the Boost. It successfully authenticates and shows a good connection, but no Internet.
