amolbak
4 years agoNeighbour
Installed wifi booster, but what do i do with old wifi id
I installed the wifi booster, but it appears I have two wifi networks to select from (my old and new). Is this correct? Do I need to connect the two networks or delete the old or do I just chose fr...
kamak
4 years agoAmbassador
I assume you mean the second/new WiFi SSID, not network. Isn't it all on one LAN/network? Isn't the Booster just a WiFi extender or AP? ie All your devices can see each other even if they are on separated WiFi SSIDs.
- Nighthawk4 years ago
The Boost is it's own AP with separate SSIDs from the T3200. It still uses the Telus router for DHCP. The Boost units are in theory supposed to be an extender if used with the Telus Wifi Hub.
- kamak4 years agoAmbassador
Right, so for example a Google nest on SSID#1 broadcasting from said T3200M would be seen by a device on SSID#2 broadcasting from the booster, even if the booster is in AP mode, and whether or not they are on different bands 2.4 and 5G. I also interpreted the OPs comment as the Booster has two broadcasting bands, 2.4G and 5G? just like the T3200? Unless Smart Steering is active? Even with separated bands, they can still see eachother on the same network. Unless Isolation is activated.
