amolbak
4 years agoNeighbour
Installed wifi booster, but what do i do with old wifi id
I installed the wifi booster, but it appears I have two wifi networks to select from (my old and new). Is this correct? Do I need to connect the two networks or delete the old or do I just chose fr...
4 years agoWhichever you prefer. When I attached my boost I left the old wireless networks as-is on my Telus router. I have some devices close to it that are fine. I did connect a number of other devices to the Boost but I didn't delete the old network settings. For me the devices typically just connect to the Boost instead of the original network. If for whatever reason the Boost isn't working, they'll just reconnect to the original network as a backup.
amolbak
Thank you that's helpful 🙂
