newbie66
1 month agoNeighbour
Installation and Wi-Fi Plus and TV
Hi All, I am not a Telus customer yet but am considering switching from Bell Fibe to PureFibre 1.5 with Wi-Fi Plus. The sales folks were not able to answer all of my questions. With Bell, fibre ent...
- 1 month ago
Yes, they should be able to use your existing Ethernet wiring. The setup would probably look something like this:
Basement: Fibre enters and connects to a Network Access Hub (NAH).
First Floor: Your existing Ethernet cable plugs into a Boost Wi-Fi device.
TV Setup: In this case and unlike the other provider you don’t need a separate "base station." The TELUS TV Digital Box connects directly to the Wi-Fi device via Ethernet or Wi-Fi.
Second Floor: A second WiFi Boost device would ensure wall-to-wall coverage. But the technician will do their signal readings and decide on placement and number of units required to give you optimal coverage.
newbie66
thanks very much for prompt and thorough reply.
- TELUS_Support25 days ago
You're welcome!
