newbie66
4 months agoNeighbour
Installation and Wi-Fi Plus and TV
Hi All, I am not a Telus customer yet but am considering switching from Bell Fibe to PureFibre 1.5 with Wi-Fi Plus. The sales folks were not able to answer all of my questions. With Bell, fibre ent...
- 4 months ago
Yes, they should be able to use your existing Ethernet wiring. The setup would probably look something like this:
Basement: Fibre enters and connects to a Network Access Hub (NAH).
First Floor: Your existing Ethernet cable plugs into a Boost Wi-Fi device.
TV Setup: In this case and unlike the other provider you don’t need a separate "base station." The TELUS TV Digital Box connects directly to the Wi-Fi device via Ethernet or Wi-Fi.
Second Floor: A second WiFi Boost device would ensure wall-to-wall coverage. But the technician will do their signal readings and decide on placement and number of units required to give you optimal coverage.
4 months agoYes, they should be able to use your existing Ethernet wiring. The setup would probably look something like this:
