MariuszStepien
3 years agoNeighbour
I upgraded to PureFibre 1.5 GB but speed remains 1GB
It is a simple set up, one hard wired computer and Cat6 cable. Telus support not very helpful. I'm confused - did all the restarts etc... Any suggestions ?
- 3 years ago
MariuszStepien Wrote: It is a simple set up, one hard wired computer and Cat6 cable.
A number of caveats on installing 1.5Gbps internet:
1. Telus says that the 1.5Gbps is cumulative i.e you'll see a total of 1.5Gbps download amongst all your devices. Not necessarily on a single device.
2. Some of us have created systems that can, and do support the total bandwidth on a single connection.
3. Undertaking the creation that supports a single connection is not for the faint of heart. You require additional hardware, and some knowledge to obtain these speeds.
My suggestion would be to have a gander at the following YouTube videos' for an idea of what may be involved with what you want to achieve.... Cheers...
https://www.youtube.com/watch?v=5WWO_4p4UP0&list=RDLV2P6Miz-wRcw&index=2
https://www.youtube.com/watch?v=gzk69kHLu1o
RyDawg
3 years agoAdvisor
Was wondering what router you currently have from Telus? I believe you need the new Network Access Hub in order to get speeds beyond a gigabit, as that has the 10G ethernet port. Not sure about the older Wi-Fi hub though.
- DrPacman3 years agoRockstar
RyDawg Wrote: I believe you need the new Network Access Hub in order to get speeds beyond a gigabit, as that has the 10G ethernet port.
This is indeed a correct assumption. You will require the NHA style Access hub to achieve the increased speeds.
The attached is an example of the current supported style of hub capable of achieving the 1.5Gbps, 2.5Gbps speeds.... Cheers...
