MariuszStepien
3 years agoNeighbour
I upgraded to PureFibre 1.5 GB but speed remains 1GB
It is a simple set up, one hard wired computer and Cat6 cable. Telus support not very helpful. I'm confused - did all the restarts etc... Any suggestions ?
- 3 years ago
MariuszStepien Wrote: It is a simple set up, one hard wired computer and Cat6 cable.
A number of caveats on installing 1.5Gbps internet:
1. Telus says that the 1.5Gbps is cumulative i.e you'll see a total of 1.5Gbps download amongst all your devices. Not necessarily on a single device.
2. Some of us have created systems that can, and do support the total bandwidth on a single connection.
3. Undertaking the creation that supports a single connection is not for the faint of heart. You require additional hardware, and some knowledge to obtain these speeds.
My suggestion would be to have a gander at the following YouTube videos' for an idea of what may be involved with what you want to achieve.... Cheers...
https://www.youtube.com/watch?v=5WWO_4p4UP0&list=RDLV2P6Miz-wRcw&index=2
https://www.youtube.com/watch?v=gzk69kHLu1o
FuzzyLogic
3 years agoWhat is the speed limit of your network card on your computer? Likely 1GB.
MariuszStepien
My Ethernet - 10/100/1000BASE-T Gigabit Ethernet (RJ-45 connector) - which should support connection up to 10GB
- Jimmyinbc3 years agoFriendly Neighbour
This 10/100/1000BASE-T Gigabit Ethernet speed is Max 1Gb ( most new motherboard support 2.5G also the new Wi-Fi 6 card can reach 2.4G speed...
- giantbrownguy3 years agoRockstar
I also read in another forum, on some of the Telus modems, one port is available for 1.5 GBPS, but the rest are limited to 1 GBPS. Once you have the right set up, I would test it.
- DrPacman3 years agoRockstar
The newer ONT/Modems have a 10Gbps port that can support a direct connection, or be placed into bridged mode to connect additions user supplied equipment. This would allow for an entire networks ability to connect at 1.5Gbps or faster connections. Cheers
MariuszStepien Wrote: which should support connection up to 10GB
No sorry, it only supports a 1Gbps connection... Cheers...
- MariuszStepien3 years agoNeighbour
That's helpful thank you.
