mopudding
4 years agoOrganizer
How to connect wireless 4k box to wifi booster?
My T3200 router's wireless signal is too weak for my living room wireless 4k box. So, I added a Telus wifi booster, connected my 4k box and it works great. I've now added a second booster in the ...
- 4 years ago
To add to my comment, it is best to call in to technical support so they can determine if your WSTB RSSI (Received Signal Strength Indicator) is within the threshold. If not, they will likely book an appointment for a technician to install a wireless extender where you can hardwire/wirelessly connect your VIP5602 so it has closer proximity to the wireless access point (WAP).
FuzzyLogic
4 years agoNot sure which booster you are using but presumeably it has a WPS button on the back. I believe the only way to connect a Telus box to your wifi is with the WPS button as per the self installtion instructions:
Optik TV self install | TELUS Support
There is also helpful info in the troubleshooting section.
- mopudding4 years agoOrganizer
WPS button on the booster didn't work. The Telus box just doesn't see it
