minchadw
1 year agoFriendly Neighbour
How should I configure home network with switches and nests.
I have an unmanaged switch (d-link DGS-1016c) in a data closet supporting wired connections throughout my house. Since installing the switch, my Optik TV ceases to work (drops network connect in abou...
- 1 year ago
Your previous setup of ONT > T3200 > Optik Box is no longer possible at your new place? The T3200 has multiple LAN ports on it so if there's a dedicated ethernet run to where the Optik box is, plug that directly to the T3200. You can have the Eero and your switch plugged into another of the LAN ports on the T3200.
minchadw
Scenario 1 has the switch between the T3200 and the Optik box. However the problem there is the switch does not like having a router in front of it, and I get not network traffic, irrespective of Optik box. Somewhere I read switch has to be in front, however in comments on this site, seems lots have them "downstream".
Scenario 2 has the switch first followed by T3200 then Optik box. Network ports work on switch by Optik box drops. I'll see what info I can get regarding the switch.
- Nighthawk1 year ago
- minchadw1 year agoFriendly Neighbour
I could go back to this setup, but my initial testing was that the switch does not work connected to the T3200. As this failed, I didnt try connecting the Eero to the T3200 either.
The switch could be malfunctioning also. It doesn't seem to be behaving normally.
