qukidonk
3 years agoNeighbour
How do I change wireless setting from "long preamble" to "short preamble" ?
I recently remote play ps5 on steam deck and got lot of scratchy audio, somebody on reddit said by changing your wireless setting from "long preamble" to short will fix it. But I try to look under e...
DrPacman
3 years agoRockstar
qukidonk Wrote: "Switch from "long preamble" to "short preamble"
if you are utilizing the Telus provided hardware for your installation, I don't believe that would be a setting offered the user. Normally you'll only find that sort of setting in a aftermarket router with more advanced firmware.
