Claysmith1
2 years agoNeighbour
How come I have to run a speed test to unlock gigabit
https://youtu.be/I_srizrCYI8 See above. My connection consistently throttles to kilobytes until I run Telus' speed test. After, and ONLY after, I run that, my speed goes to the rated speed where it...
2 years agoWhich wireless router are you using? What happens if you try uploading from a computer connected to ethernet?
Claysmith1
I doubt running a Telus speed test and getting uncapped bandwidth so Telus can point to the speed test and say I am getting rated speed has anything to do with what hardware I am using. This is just pure shady. It appears to be at the service level.
The same throttling occurs when using my mobile for uploads through both the included telus router as well as downstream through a very nice GT-AX11000.
It will also occur on PC with hardwire.
- Claysmith12 years agoNeighbourhttps://youtu.be/VF4K89pFFDs Heeeere we go again. From x kbps to 20 Megs
Related Content
Gigabit internet - only limited to 100mbps connection from modem to gigabit router
Hi all, I've recently upgraded to gigabit internet. I bought a gigabit router and connected my Wifi hub to it. However, I am only getting a 100mbps connection over WAN. I have confirmed that I ha...Solved12KViews8Comments
